firing order on md?
jonnnny2006
05-31-2007 18:52:47
what is the firing order on a md? is it 1-3-4-2-?
i know the mag spins backwards so ill take that into consideration. plus i have not moved the motor from the spot of when i took off the mag. so i should just be able to point the rotor one plug at a time and eventually it should line up right? i had to retime the little gears in the mag and it works perfect now. to i have to retime the mag to the engine all over or will i be able to put it on and move it one plug at a time till it is right? but i need to know the correct firing order
Haas
05-31-2007 18:59:41
 Re: firing order on md? in reply to jonnnny2006, 05-31-2007 18:52:47
Firing order is 1342. See my post in reply to yours below.
jonnny2006
05-31-2007 19:00:46
 Re: firing order on md? in reply to Haas, 05-31-2007 18:59:41
going out to get her gpoing now. thanks for you prev reply!!!
