M W 9speed for H
Dave S.
05-31-2007 20:15:57
I am installing a M & W 9 speed in my 45 H, would anyone have a copy of the original instructions? I don't want to mess this up especially where I drill the hole for the shift lever. Any help would be greatly appreciated. Dave
r4etired
06-01-2007 17:43:31
 Re: M W 9speed for H in reply to Dave S., 05-31-2007 20:15:57
The cable hole should be drilled in line with the top transmission internal threaded bolt.Stay backfar enough not to kink the cable inside the housing,going back to far will make a sharp bend to mount the control on the light bar. Make sure your cable is good,not streched and is adjusted properly,Many failures were caused by the shifting gear not engaging all the way and rounding off the direct and OD gears. NAPA has a truck pto cable that is the correct OD to thread in the pass through bolt, I leave the rubber coating on the exposed portion.
kfox
06-01-2007 07:25:39
Dave, I have a PDF copy of the manual. Need your email address. ken
