Gaskets vs RTV or Permatex
JohnG(TX)
06-01-2007 11:20:51
I am rebuilding the rear half of my 1929 Regular now, and the gaskets for the bull gear housings and such are no longer available. What would the pros and cons be of just using RTV or such instead of gaskets? There is no pressure built up inside, so that is not a concern. It would just have to hold in the gear oil. On my F-20, I made my own gaskets, and that worked out OK. It cost money and was time consuming. I am wondering if RTV would do as well so I can avoid this step.
justanothercase
06-01-2007 20:06:38
 Re: Gaskets vs RTV or Permatex in reply to JohnG(TX), 06-01-2007 11:20:51
you could get some gasket paper and tap out a new one.i use rtv/permatex with most of my gaskets it holds them in place and protects the hearing of anyone around ;-)
NDS
06-01-2007 13:45:27
Have seen a lot of posts on this site that say the Farmall gods would not approve anything but a gasket but I have been using the RTV sealer for 40 years and have never had a problem with it.
Van in AR
06-01-2007 13:24:03
I use the "Right Stuff" gasket maker available at NAPA comes in a cheese wiz can and is much better than RTV, best stuff I found yet
Van
El Toro
06-01-2007 13:22:36
GM has been using RTV on vehicles for a good number of years. It was a little difficult to get the pan loose. I inserted a thin blade putty knife and it pop off. I used RTV when I reinstalled the pan it never leaked. You don't need to worry about the gaskets being aligned
either. Hal
Steven@AZ
06-01-2007 12:47:27
Many of the newer vehicles, etc. are put together with just RTV type sealers and no gaskets. Honda is one of them that has their own "Hondabond" that works great.
As long as the thickness of the gasket isn't needed to set a clearance, you should be fine with just sealer.
Spook
06-01-2007 20:15:24
 Re: Gaskets vs RTV or Permatex in reply to Steven@AZ, 06-01-2007 12:47:27
Yeah, we have a robot that applies a sealant plus a rubber rope gasket to our engines. (GM)
dej(jed)
06-01-2007 11:30:14
I do it all the time. Heck, I even use a high temp. gasket sealer on old head gaskets. I just torque tehm an extra 5 psi.
