140 steering
badger Bob
06-01-2007 15:04:12
I have a 1965 farmall 140. and the steering is lose.I have about 1/4 play in the wheel. its not in the worm. is there a woodruff key in the output shaft that can be 1/2 worn out. or is there somthing els that iam missing ? thanks Bob
Badger Bob
06-02-2007 11:30:14
 Re: 140 steering in reply to badger Bob, 06-01-2007 15:04:12
Ok it was the woodruf key. it had shered and was binding the shaft. lucky it was the only thing making it steer. thanks to all you guys I have this thing steering 100%. thanks to all who posted info. thanks Bob
BDM
06-02-2007 23:01:04
 Re: 140 steering in reply to Badger Bob, 06-02-2007 11:30:14
Mine was slightly loose. Since the gear set is good, I'm wleding it to the shaft.
Hugh Mackay
06-01-2007 17:45:44
Bob: If the steering wheel shaft has no end movement those bearings will be fine.
Usually most of the problem is two woodruff keys on the vertical shaft in steering box. Inside the gear has one and also the steering control arm has one. Between them, and if bad enough one can get over a full turn of free travel on the steering wheel.
Badger Bob
06-02-2007 05:10:15
 Re: 140 steering in reply to Hugh Mackay, 06-01-2007 17:45:44
well guys thanks for all the info. Ill rip in to this this morning and let you know how I come out. thanks Bob
Jim in NC
06-01-2007 20:39:30
Hugh, This loose steering problem comes up a lot on these offset farmalls. Several years I was at a local Case-IH dealer and I asked if there would be anything wrong with welding the gear to the shaft. I was surprised to hear something like "we fix alot of them that way." Have you ever heard of this? Do you think it would create any future problems?
SuperA-Tx
06-01-2007 18:40:31
Hugh,
I didnt do the work on our 140 so I'll have to just give you what I know. The guy that does a lot of my work said it wasnt the woodruff key on mine but a short pin, about two inches long. It goes thru the shaft and over time wears out and the steering starts to kind of go. Its an easy fix but one that really needs to be tended too.
Ordered a new oil filter for the 140 today. Girl at Case is kind of flirting with me. I better order more stuff.
SuperA-Tx
06-01-2007 15:34:52
Bob,
Two weeks ago we had one that the steering went out on. Found out it had been loose for a year and the Meskins kept driving it. Was a wore out pin. Had a new hole drilled and it works fine now. You have to take the axle off to get to all the stuff in there. I bet yours is wore out too.
When the steering went out the guy ran into a customers truck, of course the brakes didnt work either. We ended up buying the truck. Busted the tie rods, radiator, and one light on the tractor. Figure that one pin cost us about seven thousand.
Dont even ask me if I was pissed.
Badger Bob
06-01-2007 16:04:41
 Re: 140 steering in reply to SuperA-Tx, 06-01-2007 15:34:52
super A tx thanks for the fast reply i was going to start on it tonight but it started raining. so Ill give it a try tomarrow. ill let you know how it gos. thanks Bob
