Carb Load Screw on A
Andrew Z
06-03-2007 07:19:41
I have an A with no load screw on the carb it is a Zenith. I was wondering if I can replace the factory plug with a load screw???
Thanks for the help Andrew
CNKS
06-03-2007 12:59:12
 Re: Carb Load Screw on A in reply to Andrew Z , 06-03-2007 07:19:41
It might work. Many of those tractors run rich. That's ok if they are run daily and are kept up to operating temperature. On little used tractors, the carbon build up is excessive. You have little to lose.
gene bender
06-03-2007 10:47:55
original carb didnt have one.
Andrew Z
06-03-2007 12:26:43
 Re: Carb Load Screw on A in reply to gene bender, 06-03-2007 10:47:55
Nope, and my allis B and Super C are the same way, no load screw.
Andrew
RustyFarmall
06-03-2007 07:23:00
Yes.
Charles McNelly III
06-03-2007 21:39:18
 Re: Carb Load Screw on A in reply to RustyFarmall, 06-03-2007 07:23:00
Hi Rusty, any idea on where I might be able to get an adjustable load screw for that Zenith carb? I have a Farmall B with the same problem.
Thanks,
Charles
