Case IH 385 for Bailing?
Kansas Alan
06-03-2007 17:20:37
Is the Case Ih 385 enough tractor for running a sq. bailer and rake over about 5 acres.
dwag
06-04-2007 10:43:42
 Re: Case IH 385 for Bailing? in reply to Kansas Alan, 06-03-2007 17:20:37
Rode the rack behind a Massey 35 years back, plenty of power, but kinda scary going up and down hills, not enough weight to safely control baler and rack.
georgeky
06-03-2007 19:22:43
Yes it will work fine.
Kansas Alan
06-03-2007 20:13:05
 Re: Case IH 385 for Bailing? in reply to georgeky, 06-03-2007 19:22:43
You answering yes, is that based on experience or an educated guess. The tractor is said to have 35hp, what would the minimum horsepower be for a small bailer?
georgeky
06-04-2007 06:39:47
 Re: Case IH 385 for Bailing? in reply to Kansas Alan, 06-03-2007 20:13:05
Experiance. I would not tell you it would work if I didn't know. I have baled lots of hay with smaller tractors than that before. The 385 is basicly the same as a 424/444 and either of those are plenty of tractor to pull a baler. I have also baled lots of hay with 23 HP Super C and dads 230. I have pulled a baler with a 384 which is the same as your tractor.
dds-inc
06-03-2007 21:39:26
well, number one, raking hay can be done with my 18 HP deere. Number two, balers use the force of a flywheel to press the bales. SO 35 hp is enough to get the baler flywheel spinning and baling.
