need a little help figuring out set up cultivators
brian08
06-03-2007 20:40:38
I have figured out they are farmall from the symbol on them. It looks that the attach maybe to the side of the tractor with some large bolts it would slide on I have both sides.
It have a number on the shaft of the adjuster PO 3107A
I will try to get some pictures of them in the next couple of days.
georgeky
06-04-2007 06:32:23
 Re: need a little help figuring out set up cultiva in reply to brian08, 06-03-2007 20:40:38
I forgot to mention that they bolt directly to the front bolster of tractor. Looks like the lifting rod that hooks to the lift of tractor is missing.
brian08
06-04-2007 06:55:40
 Re: need a little help figuring out set up cultiva in reply to georgeky, 06-04-2007 06:32:23
I have what looks to be a drawbar with it also..
Any idea what they might be worth?
I dont have any farmall's sadly.
georgeky
06-04-2007 11:41:57
 Re: need a little help figuring out set up cultiva in reply to brian08, 06-04-2007 06:55:40
Not really, it depends on a multitude of things. In Ky the cultivators are worth anywhere between 150 and 400 dollars depending on what is missing. The drawbar is for a A,Super A,100,130,140 or maybe a Cub. It may be worth 50 to 100 dollars.
gfeorgeky
06-04-2007 06:27:05
Brian, those are for a C,Super C, 200 or 230.
Brian08
06-04-2007 05:03:04
third party image
Ok here is some pictures from my phone. I will take some better ones later.
Brian08
06-04-2007 05:03:52
 Re: need a little help figuring out set up cultiva in reply to Brian08, 06-04-2007 05:03:04
third party image
Here is the other one
gene bender
06-04-2007 03:54:56
What tractor they will only bolt on one way cant bee too hard to get correct.
GeneMO
06-03-2007 22:27:31
I have the original manuals for the two row mounted cultivators for an H and I grew up using the 4 row mounted ones on an M, although I do not have manuals for the 4 row. Give us a few more details.
Gene
