H Carb float height measured with gasket on?
John in CT
06-04-2007 06:09:01
I just want to double check, the float height in an H carb is measured with the gasket on? Thanks!!
RustyFarmall
06-04-2007 07:25:17
 Re: H Carb float height measured with gasket on? in reply to John in CT, 06-04-2007 06:09:01
I always set the float height with the gasket removed. The gasket gets compressed when the two halves are assembled, so if you measured the height with a new gasket in place, the float height will be off when the carb is assembled.
