bearing or bushing in 450 steering
Alan in VA
06-04-2007 14:29:05
I have a 450 that the bearing is totally worn out where the steering shaft goes through the mount just after the throttle, like it is hollowed out to the point there is nothing left to give me a small clue as to what ot look for or ask for. The IH parts book calls it a bearing and gives it a number. The IH dealer says it is discontinued. Can anybody give me any ideas as to what to do? Have a bronze bushing made? Have the tunnel machined for a bearing that will fit the shaft? $$$ Thanks very much for any help you can give me. I'm at a loss. Alan
SDE
06-04-2007 15:16:02
 Re: bearing or bushing in 450 steering in reply to Alan in VA, 06-04-2007 14:29:05
If you have that component removed from the tractor, you could take it a machine shop and ask them if they could make a sleeve to fit inside that worn out housing. They would need to bore the housing out in order to be able to get the sleeve centered properly. I assume yours is the same as my 400, and mine are worn also. SDE
