fuel line fittings
Gary in Mozarks
06-04-2007 16:12:06
I went to replace the main tank fuel line between the tank and the fuel filter on the 424 (wore a hole in it) and it doesn't look like standard brake line type double flair fittings. more like a really thin compression ferrel. Is that a speciality part or can I use a compression ferrel fitting on the new line? Thanks
teddy52food
06-05-2007 06:28:14
 Re: fuel line fittings in reply to Gary in Mozarks , 06-04-2007 16:12:06
If it has a hole wore in it, I would just braze it up.
Gary in Mozarks
06-05-2007 07:46:55
 Re: fuel line fittings in reply to teddy52food, 06-05-2007 06:28:14
Tried that, but one of those ferrels was aparently plastic (naturally, right next to the hole worn in it) and it went poof.
El Toro
06-05-2007 04:10:04
If you need to cut the gas line be sure to use a tube cutter. Hal
Bob
06-04-2007 16:50:02
You need IH part number 19 985 R1 ferrule/nut 1/2"-20 HI-DUTY fuel fitting.
CNH MAY have changed the part number, but they're still readily available from your dealer, at least as of a month or two ago.
