986 HYD QUESTION
POOR DIRT FARME
06-04-2007 20:42:31
CAN I GET A POWER BEYOND VALVE FOR THIS TRACTOR??
I HAVE A LOADER ON IT, AND I WOULD LIKE TO BE ABLE TO USE THE 3PT AT THE SAME TIME AS THE LOADER.THE LOADER IS HOOKED INTO THE HYD OUTLET, SO THE LEVER IN CAB HAS TO BE LOCKED BACK TO WORK THEN THE 3PT WILL NOT PICK UP ANYTHING. THANKS FOR ANY HELP I AM A FIRST TIME IH OWNER.
the tractor vet
06-04-2007 21:06:58
 Re: 986 HYD QUESTION in reply to POOR DIRT FARMER, 06-04-2007 20:42:31
I do not think so but don't hold me to that . You must have a valve for the loader . Now if it was me and i had dual remotes to make things easier and do away with all the fussen and fudden over this i would elimante the loader valve and just put longer hoses on the loader and use the tractor valves then the three point would work and if ya need a third valve then that could be installed as they either had two or three remotes for the 86 seires.
