Loose steering with these As Bs 100s and so on
BDM
06-04-2007 22:04:05
third party image
My 100 had steering from hell. So I disassembled it last weekend. Not being overly thrilled with the replacement sector gear, I decided to repair mine. A good friend threw it on the lath and pinned the sector gear to the sector shaft. Came out very nice. It was slightly loose on the shaft. The gear does have wear, but I'm not impressed with that Chinese cast knock off. I'm going to shim the bearing in the case head and see if I can't snug things up. The worm gear on the steering shaft is in excellent condition.
City-Boy McCoy
06-05-2007 06:09:16
 Re: Loose steering with these As Bs 100s and so on in reply to BDM, 06-04-2007 22:04:05
I think you hit the nail on the head; the experts tell me that 90% of the steering play in these models is from looseness between the sector shaft and the sector gear. One fellow told me he welds the two together and that doing that works just fine also. mike
