Re: Super A stalls out
El Toro
06-05-2007 17:09:29
If that fuel filter isn't for a gravity flow fuel system its probably the culprit. Hal
PS: Make sure you have a good fuel flow out the tank. Could be rust or dirt both blocking the fuel outlet.
JPM in WA
06-05-2007 17:15:56
 Re: Super A stalls out in reply to El Toro, 06-05-2007 17:09:29
Thanks Hal, do you think i should just get rid of the filter? How will i know if i have a good fuel flow? Is there a specific rate or is it just a visual thing?
El Toro
06-05-2007 17:29:43
 Re: Super A stalls out in reply to JPM in WA, 06-05-2007 17:15:56
I would remove it and see if the power is ok. You can hold a clean container under the gas line and open the shutoff valve to see if there's a good flow. Not just a trickle. Hal
