steering arm and axle removal
CArlton
06-05-2007 17:16:30
I broke my axle at the wheel and now I need to know if I can get the steering arm off if I use a puller,It looks as though the only thing holding the axle is the bolt that goes through it ,correct me if i am wrong.It is on farmall 300 row crop wide front end that is original.
Carl
IaGary
06-05-2007 20:18:48
 Re: steering arm and axle removal in reply to CArlton , 06-05-2007 17:16:30
Any axle I have seen is like you said but most also have a clamp around them.
Loosen the bolts on the clamp and pull the bolt that goes down thru.
I have pushed them out with a hydrualic jack by pushing off the knee on the other side.With the jack laying sideways of course.
If you can't find a replacement knee, they make weld on replacement spindles that may work.
A farm weld/machine shop can help you.
Gary
IaGary
06-05-2007 20:25:52
 Re: steering arm and axle removal in reply to IaGary, 06-05-2007 20:18:48
After rereading your post I think you just want to drop the spindle out of the knee.
Yes pull the bolt and it should go down.
Rest still holds true about welding on a new shaft to hold the wheel bearings.
Gary
CArlton
06-05-2007 20:36:39
 Re: steering arm and axle removal in reply to IaGary, 06-05-2007 20:25:52
the steering arm seems impossible to get off. I have used a puller but it broke. Iam going to get another and try again.
Carl
Montana
IaGary
06-05-2007 20:43:54
 Re: steering arm and axle removal in reply to CArlton, 06-05-2007 20:36:39
If you have a torch heat it red hot around the shaft then cool it with water and see if that will release it.
That will break the rust loose.
Gary
CArlton
06-05-2007 20:47:22
 Re: steering arm and axle removal in reply to IaGary, 06-05-2007 20:43:54
Thanks! I will try that also!
Carlton
Montana
