C carburetor
Karl Hamson
06-05-2007 17:21:10
How do I find out what kind of carb I have on my 1948 C It says Zenith Made in USA on the float bowl. When looking for a kit on this site there seems to be several Zenith carbs used on that tractor.
Thanks, Karl
TWheat
06-06-2007 17:30:20
 Re: C carburetor in reply to Karl Hamson, 06-05-2007 17:21:10
If you can take it to a CIH dealer you will save a lot of time. I just bought a bowl gasket for a Zenith B40 from my CIH dealer. Nobody else had a clue.
georgeky
06-05-2007 21:06:01
There is also a round disc on the top engine side of the carb that has numbers on it. It probably needs to be off the tractor to see it.
CNKS
06-05-2007 19:33:26
I think there were two Zeniths for the C. If the tag is missing (not at all unusual), take the bowl off the carb and compare it with the diagrams in the parts book at www.caseih.com. The shape of the top parts of the bowls are different.
old
06-05-2007 18:44:07
On the back side of the carb you should find a brass tag. It will have the numbers you need for the kit.
