Need 756D info.
49h
06-06-2007 15:17:58
I have a 1969 756 diesel and I am wondering why it says custom over the model number?Thanks
K.B.-826
06-06-2007 16:38:52
 Re: Need 756D info. in reply to 49h, 06-06-2007 15:17:58
Like the Vet said, it's the cheap version. IH built 856 Custom to compete with the John Deere 4000, which was just a stripped down 4020. The 856 Custom proved to be a good seller, so they brought out the 756 Custom. There aren't too many 756 Customs around here so I can't tell you the exact differences other than what the Vet mentioned, but I do know that the 856 Customs also had regular clamp type rear wheels while the regular 856 came standard with the wegde-locks. Every 856 Custom that I've seen had 16.9x38 rear rubber, while most regular 856's around here have 18.4x38's. The 856 Custom had a smaller air filter canister with a single filter element. Both Custom models did not have battery covers.
the tractor vet
06-06-2007 15:49:36
The CUSTOM model was the CHEAP versionas it came from the factory with only one remote valve and one head lite on both sides and a few other things that were not the same as the reg. 756 .
gmd
06-06-2007 15:27:31
I think custom means that it had some special options like the hydraulic seat or an extra remote or something along those lines.
