farmall super c steering arm
matthew webb
06-06-2007 21:07:39
I am checking into having a new style center steering arm made ,at a waterjet cutting place. this would just be a blank. you would need to get holes drilled and have any bends you want added. if interested let me know, the more he cuts the cheaper per unit.
leon
06-07-2007 03:07:59
 Re: farmall super c steering arm in reply to matthew webb, 06-06-2007 21:07:39
I presume you're talking about the center steering arm, originally a casting, on a wide front. I'd think there would be little interest unless the replacement arms were drilled, had the proper bends and were ground down to look like a casting once painted. If that were done, you'd probably sell some. It's a pretty vulnerable part, no longer available and many one sees have been broken.
georgeky
06-06-2007 22:05:57
What for? The Super C is the easiest steering of the Farmalls.
