Farmall C won't idle down
Trueby
06-07-2007 18:17:37
I have a C and i used it a lot two years ago, and then let is sit for about 18 months, I started it up and it runs well at high idle, but won't idle down. Is there something common in them that I could clean out in the carb, or some other ideas of things to look for?
Brownie450
06-08-2007 03:27:49
 Re: Farmall C won't idle down in reply to Trueby, 06-07-2007 18:17:37
Check the carb to governor linkage to see if there is any binding in the pins & check for rust in this area also.
CNKS
06-07-2007 18:23:05
Unless your governor is full of sludge, I vote for cleaning the carb.
