steering arm removal
Carlton
06-07-2007 23:57:08
I have broken two pullers trying to get the arm off of the front axle, though they were from an auto house, cheap I suppose, but I still can't get it off. It is within 1/8 inch from the top of the spindle top but does't want to bugde. any Ideas?
Carl Montana
Jimmy King
06-08-2007 01:57:49
 Re: steering arm removal in reply to Carlton, 06-07-2007 23:57:08
If you are talking about the guide arm that has a bolt through in take the bolt out and drive a chisel into the split and it should lift off.
Hugh MacKay
06-08-2007 13:26:55
 Re: steering arm removal in reply to Jimmy King, 06-08-2007 01:57:49
Jimmy: 100% effective every time, drive that chisel into the split and you lift it off with thumb and index finger.
Unless he has a Scwartz, I think they are different.
