Farmall H-No oil getting to the top end.
Dej(JED)
06-08-2007 04:53:30
Thanks for the ideas and thoughts. I dropped the pan and found the problem. There is a plug in the side of the oil pump shaft. Well, there is supposed to be a plug in the side of the oil pump shaft. After pulling the pump down, checking the cam gear etc.,and then while cleaning the pump, I noticed that the plug was missing. It worked out for some unknown reason.
El Toro
06-08-2007 05:37:19
 Re: Farmall H-No oil getting to the top end. in reply to Dej(JED), 06-08-2007 04:53:30
You should've primed the pump after cleaning it and then installed the pump. Hal
Theman
06-08-2007 06:26:41
 Re: Farmall H-No oil getting to the top end. in reply to El Toro, 06-08-2007 05:37:19
Hal,the oil pump on the H is completely submerged if the oil level is correct. There is no need to prime it. The plug mentioned above is for cross-drilling to the relief valve chamber.
El Toro
06-08-2007 06:33:38
 Re: Farmall H-No oil getting to the top end. in reply to Theman, 06-08-2007 06:26:41
It's best to prime any oil pump. Hal
