Holes in H rim question
old
06-09-2007 11:46:33
Been working on fixing a couple tires that are on an H. Well there are 2 hole drilled in the cneter area of the rim about 2 inches from the hole for the stem. What in the world are these holes for?? Both rear rimes have them but I can't see what they would be drilled in the rim for.
Thanks
Thomas D Windsor
06-09-2007 13:22:07
 Re: Holes in H rim question in reply to old, 06-09-2007 11:46:33
I have two front rims off and was painting them today...so, I went to see about holes. No holes in mine but the block on the outside of the rim looks like it is rivited to the rim. I suspect your anti slip blocks are missing.
tw
Ozarker
06-09-2007 12:41:41
The holes are for rivets. There are two blocks of metal about an inch square that are held in place on the rim by the rivets. The blocks mate with a "notch" in the outer circumference of the wheel for a positive drive. I have one H with them still intact, one H where they are rusted away, and an M where they are welded to the rim instead of riveted. Bob
D Slater
06-09-2007 12:38:09
Maybe were the stop blocks were riveted. Does your rim have any?
old
06-09-2007 13:48:29
 Re: Holes in H rim question in reply to D Slater, 06-09-2007 12:38:09
Well on the rim I have off right now it has one stop block so yep probably missing a stop block and that would be why it has those holes then. Thanks
The centers from the H are going on a 340 and then the rims also will go on this 340. 36 inch tires in my area are like tring to find hens teeth but 38s can be found
