M piston rings
MTJC
06-09-2007 18:02:14
Hi guys-have a 1945 Farmall M.I want to replace the rings.The piston has 5 rings on it.3 compression and 2 oil rings.It has a number GE 11 on the piston.I can not find the rings on the net.Any ideas?THANKS
Janicholson
06-09-2007 18:19:33
 Re: M piston rings in reply to MTJC, 06-09-2007 18:02:14
Take the piston into a NAPA store, with the bore size, the old rings, and a good counter man/woman, you will be set. when installing, be sure end gap is correct, or a siezed engine will resuly. JimN
