656 3 point hitch sway
hay to cut
06-10-2007 09:10:09
Need help and ideas.I have an older Farmall/IH 656 that has alot of sway in the lift arms. I just got a disk mower and when mounted and mowing it moves around too much. I am worried that it will put undo strain on the PTO system.
Thanks
Armand Tatro
06-10-2007 17:56:14
 Re: 656 3 point hitch sway in reply to hay to cut, 06-10-2007 09:10:09
Look for a couple of holes (maby 1/2in. or 5/8in. dia.) that need to have pins in them. With the pins in them when you move one hitch bar the other hitch bar moves also. When hooked to an implement they become rigid. Armand
Nawlens_Gator
06-10-2007 09:27:44
Isn't there a 'Z' shaped solid adjustable bar that bolts to each of the 2 lower arms? Mine have that bar and it prevents sway side to side.
hay to cut
06-10-2007 09:49:43
 Re: 656 3 point hitch sway in reply to Nawlens_Gator, 06-10-2007 09:27:44
Thanks, there is a sliding/adjustable link between the lift arm and the cast base attached to the tractor. Those are heavily worn with lots of slop. Even in good condition I don't see how those would limit sway
wolfman
06-10-2007 18:21:52
 Re: 656 3 point hitch sway in reply to hay to cut, 06-10-2007 09:49:43
Those sway links have holes to drop a bolt through that'l make the hitch rigid.
Janicholson
06-10-2007 09:14:44
Solid bars can be made which locate the hitch dead center, vertically and horizontally. They would not be used when using the 3PT for any other purpose. There are restraints (supposed to be) for some sway control. The best is a draw bar attached to the tractor that eliminates the use of the 3PT for pull type implements. Some did not have that. most new tractors now do. JimN
hay to cut
06-10-2007 09:52:47
 Re: 656 3 point hitch sway in reply to Janicholson, 06-10-2007 09:14:44
Thanks, I do have restraints mounted to the lift arms and the tractor itself. Those are very worn and I can't see how they could limit sway. The mower I got is a 3 point mount.
