Order Farmall Cub Parts Online
Governor, 1949 Farmall Cub F Model
Mark Bryan
06-10-2007 12:06:23
I have fixed/replaced all needed parts. It starts and runs on high idle only. The vacuum created in the engine and against the Rockshaft Rod is formidable. I believe the Governor is the culprit. But, the "Flying Weight" operation is a bit out of my league. I'm looking for detailed manuals for removal/repair/replace/reinstall. Any and all experienced advise is also more than welcome. I grew up with this tractor. It is very special to me. Thank You. Mark B.
rterry
06-11-2007 01:50:34
 Re: Governor, 1949 Farmall Cub F Model in reply to Mark Bryan, 06-10-2007 12:06:23
I think your low speed jets are clogged, barrow a carb from friend. before you remove gov, try doing that first.
