400 Disc Brakes
Steve Weathers
06-10-2007 13:10:24
My brakes are about brand new cleaned inside housing,springs, oiled all needed parts, good splines but any time i hit my right brake it lockes down have to put in reverse to unlock. any pointers thank you
steve
Tom in Michigan
06-11-2007 17:29:14
 Re: 400 Disc Brakes in reply to Steve Weathers, 06-10-2007 13:10:24
Steve, On our SMTA we had a few thousands milled of the housing to compensate for wear. This reduces the amount of travel for the brakes to expand, and may eliminate or reduce the sticking. When we use ours on a regular basis they seldom stick. In the winter the left one sticks intermitently. Good Luck. Tom
Bob M
06-10-2007 18:46:31
Steve - If everything else is OK I'd suspect mismatched/deformed/worn out balls that separate the actuating disks. Could also be badly worn ball ramps in the disks themselves.
Steve Weathers
06-10-2007 18:23:05
 TRACTOR VET in reply to Steve Weathers, 06-10-2007 13:10:24
TRACTOR VET MAN CAN U HELP ME
