overheated farmall h
glenmoore
06-10-2007 17:31:56
HI,my farmall was running fine when it started to lose power and quit. I then discoved it was out of water. I let it cool and filled with water and tried to start. IT STOT WATER OUT OF THE STACK!! I'm sure its not good.What did I di?? thanks
lawmar
06-10-2007 18:58:01
 Re: overheated farmall h in reply to glenmoore, 06-10-2007 17:31:56
Most likely you cooked the head. You may have scored a piston also. I have a good used H engine sitting in the shed that I would sell for 300 dollars.
El Toro
06-10-2007 17:42:42
You may have a cracked head. You can pull the head and have it magnafluxed. Hal
