Follow-up question about filter screen on super C.
Mark Doud
06-11-2007 08:48:10
I posted a question a week or two ago about my filter screen assembly having liquid of some sort (sounds to thin to be oil) in hollow area of the filter screen assembly on the oil pump. I followed the instructions I received to immerse it in hot water and look for the air bubbles to find the leak.
There doesn't appear to be one! No bubbles and as far as I can tell, no additional liquid entered from the water bath.
Is it possible that the liquid inside is part of the design?
I am unable to find any additional information about this and I don't want to drill a hole and drain it when I can't find the leak and its possible that is might have been made that way.
Any additional information would be greatly appreciated!
Mark D.
Bob M
06-11-2007 11:57:37
 Re: Follow-up question about filter screen on supe in reply to Mark Doud, 06-11-2007 08:48:10
Mark - I highly doubt the float contains any liquid by design. At least I've never heard of one that does. Nor can I think of any engineering reason for it to contain liquid.
So.....I guess if the float is not now leaking, and it still has sufficient bouyancy for it to float on oil, then go ahead and install it "as is".
Also keep in mind that float pickup system was designed long before the introduction of detergent motor oils. It was provided to keep the oil pump pickup out of the sludge and stuff that would frequently accumulate in the bottom of the pan when running non-detergent oils.
Now if you are using good quality detergent oil and changing it as required, there should be no sludge accumulation. And if the pickup should later become filled and sink entirely, it's picking up oil from the bottom of the pan would not likely cause any problems.
CNKS
06-11-2007 08:58:25
Just clean it, drain it and use it. Provided you had good oil pressure before. They did not come with liquid.
