Farmall Super H Propane Carb
3mr
06-11-2007 16:44:09
My Super H seems to be hacig a problem. When I try to start it I can see Propane fumes coming fromt eh exhaust pipe while I am turning it over. When I quite turnging it over the fumes come out the air intake of the carb. I assume this is a problem in the Propane carburetor, but I have no idea how th propane carb actually works, I have taken a cover off and see nothing that jumps out as being wrong. Am I way off line, could it be a problem in the actual carb on the tractor the propane pipes into from the propane carb? I am at a loss here so any help would be appreciated.
I can be contacte at justdoitagain@hotmail.com if anybody has any ideas.
John A.
06-11-2007 21:50:41
 Re: Farmall Super H Propane Carb in reply to 3mr, 06-11-2007 16:44:09
3mr,Get a hold of.....
Everhart 2-way & LPG Supply
Lone Wolf, Okla.
Phone #....580-846-5633
He speciaizes in Ensign Carbs and Vaporizors. But he may be able to help you. Hope this helps!
Try this....On a dead cold start, both valves "off" Get the engine turning over,....just crack the "Vapor" valve,....it should start. You didn't say it it ever did start in your post above. Hollar at me tomorrow after 2:00 pm Central time.
My # is 512-577-3837. I will see wht I can do!
Later,
John A.
3mr
06-12-2007 08:02:19
 Re: Farmall Super H Propane Carb in reply to John A., 06-11-2007 21:50:41
It would start, I just couldnt regulate it and it didn trun right.
I took the regulator of last night and took it apart to replace the diaphrams. I just need to find a place to get them now.
I appreciate the assistance and offer to help further, but I wont be able to call tonight due to work. I really appreciate the offer though. If I cant find the diaphram local I will check with the guy in Lone Wolf. Im going to check with my LP provider first though.
Thanks again
Steve
3mr
06-11-2007 18:54:04
OK, I took the regulator off, that is what I was calling the propane carb. It says carb on it, but I guess in actuallity it is a regulator. After taking it apart that was confirmed. although it does say "J&S Carburetor company, Dallas Texas, Model BR" on the side plate. It has a diaphram on either side that pushes on the valve to let propane into it. Does anybody know where I can get/order replacment diaphrams. I have had no luck searching. I need to get this tractor fixed pretty quick as I use it quite often.
Owen Aaland
06-11-2007 18:23:06
The problem is in the convertor/regulator. There should be no fuel getting by the regulator until vacuum is applied to the outlet to the mixer. Depending on what system is installed it should, take either 1/2 inch or 1 1/2 inch of negative water pressure to start to open the regulator. this is a very tiny amount. It is the amount of vacuum you would apply to suck water up soda straw that much.
NDS
06-11-2007 18:08:36
I do not know what problem is sounds like you might have problem with regulator/vaporizer but BE CAREFULL you could have a explosion or fire very easily. Saw tractor with problem similar to yours way back when and vapors drifted back around driver and ignited and he had serious burns on all exposed skin.
jonnny2006
06-11-2007 16:52:17
how long have you had it?
3mr
06-11-2007 16:55:01
 Re: Farmall Super H Propane Carb in reply to jonnny2006, 06-11-2007 16:52:17
Since last October, have used it quite a bit. This is the first problem like this I have encountered.
