Order Farmall Cub Parts Online
Farmall Cub Hydrolic Box
Roger Kansas
06-12-2007 09:13:48
Can anyone tell me if there is a secret to removing the bottom cover on the touch control box on my 49 cub. I need to replace the gasket but can't get the cover to budge.
Michael Sheik
06-12-2007 11:02:10
 Re: Farmall Cub Hydrolic Box in reply to Roger Kansas, 06-12-2007 09:13:48
Just did the one on my dad's '51 Cub. That plate is really stuck on there good. Don't know if the factory used some sort of sealer on the gasket or whether is was all those years causing it to be bonded so well . I had to take a chisel with a sharp edge and wedge between the plate and housing, tapping it in a little ways in numerous locations and it finally came apart. Be careful and drive in the chisel where is does not cut into the metal on either side. Go slow!
CNKS
06-12-2007 18:32:03
 Re: Farmall Cub Hydrolic Box in reply to Michael Sheik, 06-12-2007 11:02:10
Rigid paint scraper and small hammer. Go slow, to avoid gouging the surfaces the gasket goes between. Be sure there are no burrs, etc on the scraper.
Roger Kansas
06-12-2007 12:59:31
Thank You very much. Did you have any problem finding the gasket or did you make your own?
Michael Sheik
06-12-2007 13:01:41
 Re: Farmall Cub Hydrolic Box in reply to Roger Kansas, 06-12-2007 12:59:31
Bought it from Case IH. Not too pricey!
