Farmall 460 diesel
izudropped90
06-12-2007 10:19:32
Ok Farmall experts. I just bought a Farmall 460 diesel yesterday. Can any one give me some basic info on this tractor? Value? General info? It has a row crop front end. And has T/A on it. It runs awesome and all tha sheet metal is as straight as tha day it was new. Would need paint if you were making a show tractor out of tho. On a scale of 1-5 i would say it was a 3 or a 4
Dont know much about these models so any info would be appreciated
Thanks Brent
dej(jed)
06-13-2007 07:15:33
 Re: Farmall 460 diesel in reply to izudropped90, 06-12-2007 10:19:32
I have a guy offering me a 460UD. He wants $1400 for it. He says it has a diesel knock when you first start it. Does that mean anything to anyone and is that normal? He also says it is hard to start and needs either, but new glow plugs would fix it.
Jimmy King
06-12-2007 16:46:34
I have owner a 460D since the early 1970"s, it has been used hard over the years, 7 ft. Roam Offset, 9 and 12Ft Haybine, 605A Vemeer Round baler, I have pulled my 605F with but it is not ideal on it. A very good Starter, battery, and glow plugs are very importion for it starting good. Don"t expect it to start on all 6 at once mine starts on 4 then progresses to 6 I use one 12 volt battery, the engineis a very low compression engine and should turn over very fast with the starter. There is not a smoother sounding diesel engine when it is running good. I had mine on a dino one time and it was putting out 63 HP at 540 on the PTO. rated about 52.
gmd
06-12-2007 15:11:40
my dad has one. he got his for 1400 but he had to put a new injector pump new plugs on it and one of the valves needed replaced. great tractor though. until he got the plugs and injector done it was the hardest starting piece of junk in the world. now its fantastic.
teddy52food
06-13-2007 06:02:21
 Re: Farmall 460 diesel in reply to gmd, 06-12-2007 15:11:40
Plugs on a 460 Diesel?????
Ross
06-13-2007 07:58:43
 Re: Farmall 460 diesel in reply to teddy52food, 06-13-2007 06:02:21
He meant glowplugs
jonnny2006
06-12-2007 11:05:38
sounds like your good to go
