battery for 1939 Farmall A
Linda Glovak
06-12-2007 17:00:20
WE just got a 1939 Farmall A and need to know what kind of battery it uses. Have manuel ordered but want battery b/4 it comes Thanks
Jim Becker
06-14-2007 07:51:31
 Re: battery for 1939 Farmall A in reply to Linda Glovak, 06-12-2007 17:00:20
As Gene pointed out, '39 Farmall As were all crank start. However, lights were available. Also, a starter could be backfitted by changing enough parts. Either way, the original 6-volt battery would be a Group 1. As pointed out by others, someone may have converted it to 12 volts, which is usually done by grafting on an alternator in place of the generator. If is still has a generator, it is probably 6 volt. Also, if it has a generator, after installing the battery (with positive grounded) polarize the generator because who knows how the previous awner had it hooked up! Polarize the generator before you start the engine by momentarily touching a jumper wire from the cut-out (regulator) B terminal to the GEN terminal.
gene bender
06-13-2007 16:09:10
Something is mixed up as 39As didnt have starters not until FAA 18282 in March 18,1940
Linda Glovak
06-13-2007 16:19:17
 Re: battery for 1939 Farmall A in reply to gene bender, 06-13-2007 16:09:10
By the serial number it is a Farmall A. Don't know why e1 else answered the question.
El Toro
06-13-2007 04:14:55
If it still has the battery cables on it take a look at the ground cable. If the tractor is 6 volts the battery terminal on the ground cable will fit the large + terminal on the battery so it is + grounded. The cable to the starter should fit the - terminal on the battery. If these cables are cracked or frayed I would replace them with 00 cables. Hal
old
06-12-2007 18:47:02
When new it would have been 6 volts but, if it has been changed to 12 volts putting in a 6 volt bettery could cause big problems. If it has a genny on it then its still most likely 6 volts but if it has an alternator on it then it will be 12 volt - ground. If 6 volt it should be + ground
City-Boy McCoy
06-12-2007 17:53:16
It is a 6-volt. The size is what is called "Series 1" (one). The last one I bought, I got at Auto Zone or Advance Auto Parts.
History guy
06-12-2007 17:17:46
I just bought a battery for my 1944 Farmall A and I just went to the Case IH dealership and bought one. It is a 6 volt. It only cost me 55.00. Have a good day!
Aaron
