Fast Hitch Cultivators
Cmore
06-13-2007 10:31:08
Did IH ever make a small pronged 2 row Fast Hitch cultivator?? I'm gettin to old to mount the front mount ...Thanks, Cmore
SiouxFan
06-13-2007 18:54:21
 Re: Fast Hitch Cultivators in reply to Cmore, 06-13-2007 10:31:08
Here is a link to a fast hitch "scratcher" cultivator on ebay (I assume this would be for Super C / 200 but don't know):
Link
georgeky
06-13-2007 21:01:03
 Re: Fast Hitch Cultivators in reply to SiouxFan, 06-13-2007 18:54:21
That is only the rear section for a front mount cultivator. It is for newer tractors than the Super C/200. It will not slide into hitch sockets completely due to the lift rod on Super C/200. It is likely for a 230,240,350,450 and newer with the traction control hitch.
georgeky
06-13-2007 16:01:22
If you can't find one with small prongs you can cut a half inch off the bottom of a large prong set and they will work fine.
Dej(Jed0
06-13-2007 10:46:42
I have never seen a fast hitch cultivator. There are a ton of 3 point cultivator systems though. It wouldn't be real hard to convert your tractor to 3 point or vice versa. The rear ones are a real bear to cultivate with though.
Charlie M
06-13-2007 13:57:41
 Re: Fast Hitch Cultivators in reply to Dej(Jed0, 06-13-2007 10:46:42
My Dad had a new 3 row one back in the mid 60's. Extremely easy to hook up. Had to get used to the cultivator being behind you instead of watching the front like on our H.
Ksfarmmer
06-13-2007 10:43:31
We had a four row fast hitch cultivator for our 560D. Sure was a breeze to hook up compared to the old front/back mount we had earlier for the M, that, thankfully, I was too young then to do anything but watch what seemed like an all day affair to hook it up.
