Order Farmall Cub Parts Online
Cub vs. hay rake
AlexLV
06-13-2007 10:49:05
Can a Cub pull a hay rake at all? Thanks. Alex
AlexLV
06-13-2007 11:26:38
 Re: Cub vs. hay rake in reply to AlexLV, 06-13-2007 10:49:05
Thanks for answering so quickly! I just didn't want to hook up to one and tear something up. Alex
Andy Martin
06-13-2007 11:17:17
The problem will be the Cub is so slow in all but road gear, and most hay fields are way too rough in road gear.
old
06-13-2007 11:12:12
A cub should handle a rake if its ground driven and not real big. Say like a NH 5 bar etc. Now if the hay is real thick it might have a little problem but it should do it.
Lucien cyr
06-13-2007 11:06:22
My 1948 Cub pull a dump rake as if it was not even there.
oldnnew
06-13-2007 11:05:05
Sure. I use my Cub Cadet lawn tractor to pull mine when I need to move it to mow the grass underneath it.
