Regular Fuel tank
Dan in Ore
06-13-2007 11:08:40
Here is a picture of the fuel tank I just picked up that came off of a Regular. Is the threaded in cap proper on these? What did the starting tank look like?
Dan
Farmallgray
06-14-2007 15:16:02
 Re: Regular Fuel tank in reply to Dan in Ore, 06-13-2007 11:08:40
All Regulars had threaded caps from the factory. I have seen a lot of them (including mine)with 1/4 turn caps but they apparently have had their tanks replaced. There were a lot of subtle changes and improvments on all the F-series tanks. The early ones on the Regulars must have been prone to cracking and or leaking.
Bob Kerr
06-13-2007 19:52:17
My 29 10-20 had the same cap, and I have seen some other regulars that had it also. There was another style of cap that had finger grips on it but I think those were for earlier...I think my "parts 27" 10-20 has caps like that with the finger grips.
F-Dean
06-13-2007 18:15:32
The early f-20s had the treaded cap so it is logical that the Regular did also. Many of the Regulars had "Field Upgrades" such as gear steering. Perhaps some of the fuel tanks were upgraded.
James Williams
06-13-2007 14:11:01
Dan,My 1928 does not have a treaded cap,My 1926 10-20 had a treaded cap
jimmy
Big Red Man
06-13-2007 11:27:22
I believe "unforgiven" is wrong. We had a late model regular and it definitely had the threaded fuel cap (like the one in the photo).
the Unforgiven
06-13-2007 11:47:44
 Re: Regular Fuel tank in reply to Big Red Man, 06-13-2007 11:27:22
That is always a very real possibility!
Dan in Ore
06-13-2007 11:13:40
 Trying the picture again in reply to Dan in Ore, 06-13-2007 11:08:40
third party image
hope this one works
the Unforgiven
06-13-2007 11:23:16
 Re: Trying the picture again in reply to Dan in Ore, 06-13-2007 11:13:40
Not sure, but I think the threaded cap is for a fairly early tractor. The starter tank is about 6 X 12? and stands vertical behind the main tank.
