IDENTFY
JUSTIN BENSEL
06-14-2007 09:33:11
I JUST BOUGHT AN INTERNATIONAL TRACTOR AND THE SERIAL NUMBER PLATE THERE IS NOTHING ON IT AND THERE ARE NO NUMBERS FOR WHAT MODEL IT IS IT'S A 1950'S VINTAGE AND THE ONLY LABELS ON IT ARE UTILITY AND THAT IT HAS A TORQUE AMPLIFER WITH A TWO POINT HICTH. IT HAS A FOUR CYCLINDER GAS ENGINE WITH A TEN GALLON GAS TANK. IF ANY ONE CAN HELP I CAN USE IT THANKS
Hugh MacKay
06-14-2007 18:38:13
 Re: IDENTFY in reply to JUSTIN BENSEL, 06-14-2007 09:33:11
Justin: I don't call it yelling, just good easy reading for old eyes.
Go to the left of your svreen, click on tractor photos then type in, one at a time International 300, 330, 350, 240 and 340. that is all the 4 cylinder utilities out of the 50s. You'll have to do each one separately, however just click on search and it will bring up all photos in there of the particular model you type in.
gmd
06-14-2007 17:37:53
odds are if its all red then its a 300 or 350. if its red with a bunch of white then its a 240 or 340.
georgeky
06-14-2007 19:00:50
 Re: IDENTFY in reply to gmd, 06-14-2007 17:37:53
350s have white on them as well.
Mike CA
06-14-2007 13:05:46
Justin, if you could do us one more favor... Please look over at the left side of your keyboard and tap the 'Caps Lock' key once. It is generally considered proper internet etiquette to not use all caps, as that is considered "yelling."
Thanks
Andy Motteberg
06-14-2007 11:22:40
A photo would help a lot.
Andy.
Randy in NE
06-14-2007 10:32:06
You might want to look in the photo gallery to the left of this page and find a model that looks like yours. At that point there are a lot of very knowledgeable and helpful individuals on this site that will be more than happy to answer any question you may have.
Janicholson
06-14-2007 09:39:14
300 or 350 Utility are most likely.
Casting dates, and engine size from the right side near the oil filter will assist in correct ID JimN
