Farmall M carb. problems
MTJC
06-14-2007 19:53:19
Hi guys-rebuilt my carb,checked float level,all kinds of gas in carb and no gas to the plugs.I can hold my hand over air intake and feel good suction.Cleaned all passages in carb-after choking awhile gas comes out of air intake tube.I am really stumped on this.Any ideas sure would be appreciated.Thanks Mike
Rootsy
06-15-2007 06:10:44
 Re: Farmall M carb. problems in reply to MTJC, 06-14-2007 19:53:19
strip a piece of wire.. take a copper strand and chase alllll lll of the orfices and air bleeds... any crud in any of them will cause inability to adjust the carburetor properly... It's just one big balancing act so you have to get everything weighted correctly...
RustyFarmall
06-15-2007 07:34:57
 Re: Farmall M carb. problems in reply to Rootsy, 06-15-2007 06:10:44
And how do you get that wire out of the that orifice after it becomes lodged and breaks off?
RustyFarmall
06-15-2007 04:51:56
These old carburetors are much more complex than most folks realize, and are not so easy to rebuild. Simply installing a "kit" usually accomplishes nothing. The reason to rebuild a carb is because it is dirty, dirty, dirty. You need to clean, clean, clean.
City-Boy McCoy
06-15-2007 04:17:12
I have heard of guys putting a table spoon of oil in each cylinder after a carb rebuild in order to enhance ring seal and increase suction from the carb. Once, I placed a small amount of gasoline in each cylinder to get one started after a carb job. It did the trick. mike
Dave S.
06-14-2007 20:19:31
I soaked my 300 carburator in cleaner for 4 days, washed it up, blew it out with air and thought it was clean but wouldn't start (no gas to cyl). Took it back apart and found the main jet was still plugged. Dave
Patrick Martin
06-14-2007 20:03:14
Is it heavily corroded or just looks like it has seen better days?
Sometimes they just don't take the kit and you have to go with a new one.....
