Order Farmall Cub Parts Online
Cub exhaust
Cris
06-15-2007 20:01:34
I just bought a 1955 reg. cub and it has the underhood exhaust. It only has a pipe from the manifold down to in front of the rear wheel. Is there suppose to be a muffler on it or did it come this way originally? Also what was the reason behind going under the hood?
Thanks
Daniel Robertson
06-16-2007 13:07:21
 Re: Cub exhaust in reply to Cris, 06-15-2007 20:01:34
third party image
Here's one.
Cris
06-16-2007 18:42:31
 Re: Cub exhaust in reply to Daniel Robertson, 06-16-2007 13:07:21
That Cub in the picture has the very same exhaust mine has
Thanks
Jim Becker
06-16-2007 08:02:12
Starting in late '54, the standard configuration for Cubs was the underslung exhaust. The pipe should reach to near the front of the transmission housing and a muffler should attach at that point. The original muffler had a down deflector stamped into the outlet pipe. Many generic replacements didn't have that feature.
Steve Butram
06-16-2007 06:57:06
The cub should have a muffler attached behind the mounting bracket attached to the front of the transmission
Mark Ollila
06-15-2007 22:12:51
Cris,
I have a 1955 Farmall Cub (not a Lo-Boy) and it has the under-hood/under-slung exhaust. The exhaust when I bought the tractor exited out of a short pipe (which is part of the muffler) under the drive axle. On my Cub, I have replaced the muffler with a piece of pipe turned ground-ward and slightly pinched at the end of the tailpipe to quiet the exhaust note. I don't know if the muffler was "standard" or a "special attachment". Guy Fay might know.
Mark
billde
06-15-2007 21:23:38
Yes there should be a muffler. I guess it was done for clearance purposes. I have them with both styles of exhaust. Is there a hole in the hood for the exhaust, some were converted.
GA Dave
06-15-2007 20:43:11
third party image
Cris, I think you have a cub utility!!!!! !!!!! Put a muffler on it if it's too loud for you. I have never seen a cub with underslung exaust but I've not seen everything YET!. Sure would like to see a picture. David.
