Is 1949 Farmall an A or super A?
Linda Glovak
06-16-2007 09:21:46
We are still trying to identify our tractor. Found stamping that said 1949 A but can't find where the A was made in 1949-only has serial numbers thru 1947. Help What is it? Would it be Super A? Thanks- He doesn't use computer so I try to find out for Him.
Linda Glovak
06-16-2007 15:02:14
 Re: Is 1949 Farmall an A or super A? in reply to Linda Glovak, 06-16-2007 09:21:46
On the flat machined surface the numbers are FAB1C3C7. By the #1 plug the numbers are 6342DD with a 2 under that. On the seat bracket is US Pat no. 2,470,907. Made in Canada is also on the seat bracket. I can find no numbers like these in serial number listings
El Toro
06-16-2007 15:21:59
 Re: Is 1949 Farmall an A or super A? in reply to Linda Glovak, 06-16-2007 15:02:14
That 6342DD is the head PN. You need to look on the block just below the head for a flat machined
surface. Hal
Jim Becker
06-16-2007 17:49:21
 Re: Is 1949 Farmall an A or super A? in reply to El Toro, 06-16-2007 15:21:59
6342DD is the block PN, not the head. Could "FAB1C3C7" really be "FABM 10307"? If so, the engine at least is 1940 Farmall B.
Dave BN
06-16-2007 13:28:10
Where did you find a stamp that says 1949 A? I don't know of any such marking on tractors. The serial number should be on a tag rivited to the left seat support. Is the front axle round or square? Are their braces from the front axle to the frame/engine? All of these clues will help us tell you what tractor you have. Posting a picture would help even more. Dave
EL Toro
06-16-2007 09:34:12
Does the tractor have hydraulics? The Super A did
and the serial numbers for them started at 250001.
The engine may have been replaced if it's an A.
Look aroud the seat bracket for the SN. Hal
PS: There's a flat spot on the engine block beneath the No1 sparkplug that should have a number. It may be covered with dirt or heavy paint.
georgeky
06-16-2007 09:27:28
If it has hydraulics it is likely a Super A. They were built in Louisville. There should be a serial number on the tag under the seat. If you post that we could tell for sure what it is. If there isn't a tag the number will be on the right side of engine near the number one plug on a flat machined surface.
billde
06-16-2007 09:27:15
1949 would make it a Super A. It would help to post the serial number to be sure it is a 49.
