Super C Leaking from Manifold
Charles TX
06-16-2007 14:59:52
Replacing manifold, removed old manifold and have anti-freeze leaking from the last manifold bolt on #4 cylinder. I"m guessing this is a blown headgasket or possibly a cracked head. Anyone had this happen? The tractor still was running good.
Pappy
06-16-2007 22:56:30
 Re: Super C Leaking from Manifold in reply to Charles TX, 06-16-2007 14:59:52
On my 200, the rear bolt on the manifold was threaded into the water jacket. Just goop up the bolt and install it.
J.J. from Afton
06-16-2007 15:31:46
There should not be anything wrong with it all. If I am correct it is the same concept as the F-12 where the bolts/studs that hold the manifold thread into a the wall of the water passage on the head. So when you remove the manifold you need to drain the antifreeze and remove all the bolts. Than you have to put thread sealent on the studs/bolts before putting them back into the head to prevent future leaks.
