Farmall Super A Steering Box
R. Baker
06-16-2007 18:06:39
Does anyone know where to get a rebuild kit for a SA steering box? When I add fluid (oil 80Wt.) to the box it drips out the bottom. Also, the tractor is somewhat hard to steer (turning to right)and it turns sharper in one direction than the other. I don't know if that is just part of a SA nature. (first time owner)Any help will be appreciated. Thanks Robert
gene bender
06-17-2007 06:32:05
 Re: Farmall Super A Steering Box in reply to R. Baker, 06-16-2007 18:06:39
Bushings,bearings,seals and a new key are all avail from the dealer.
gmsupera
06-16-2007 19:56:58
R Backer the dealer will have parts for your sa I took mine apart and found out that if someone got in there and didnt mesh the gears so that they have the same amount of turns each way you will end up with more turns one way or the other
