Tractor quit moving?
SCOTT300IA
06-16-2007 19:38:33
I was mowing today with my 1955 Farmall 300 and suddenly the trator acted like it was out of gear, but it was in second. Now it won't move at all. It shifts into gear with slight grinding but will not move. Did I lose the clutch or is there some type of pin or something I lost? Will I be spliting the tractor soon?
SCOTT300IA
06-17-2007 18:36:44
 Re: Tractor quit moving? in reply to SCOTT300IA, 06-16-2007 19:38:33
Tractor does not move with TA in high or low, Belt pulley will not move also. Tractor has a independent PTO, it works. Opened the inspection cover on the belly of the tractor and there are little springs, which I assume are from the clutch, laying on the covers inside. Sounds like time for a new clutch!
Hayfarmer
06-17-2007 08:34:59
Does it have a TA? No chance the TA slipped into neutral is there? Or maybe a pin fell out of it. Does it move in either high or low on the ta?
Wardner
06-16-2007 20:13:19
You say it won't move at all. I assume that means all speeds. What about your belt pully and PTO or IPTO?
No diagnosis without a complete history and list of symptoms.
jonnnny2006
06-16-2007 19:52:57
spliting the tractor is not that bad..... . you will be able to fix it..
