This is what I call a super m
jonnny2006
06-17-2007 22:13:19
third party image
She has front wheel assist that make this bad girl even meaner! I would love to take that for a nice ride! I think it looks great, i wish they actually made these. this is not mine i give all credit to the man who is brillant with old iron hes has the most awesome collection i have EVER seen.
26Red
06-18-2007 07:45:26
 Re: This is what I call a super m in reply to jonnny2006, 06-17-2007 22:13:19
Where was this one located? I would like to see one in person. Did you buy that MV?
gene bender
06-18-2007 02:55:41
Is that the ELLWOOD front assist that was avail?
CRUSADER
06-17-2007 23:07:54
Now that's one M that can get the job done and also get a lot of attention. Any chance that the owner would part with some of the plans that were used to adapt the front wheel drive assist?
Wardner
06-18-2007 11:20:23
 Re: This is what I call a super m in reply to CRUSADER, 06-17-2007 23:07:54
It could probably be reproduced for around $7-$8 thousand. I'll take your order if you like. I have an original that can be used for reverse engineering.
This only includes the gear box and wheels. The axle is military surplus from a WW3 duece and a half. Those should be plentiful.
Nat 2
06-18-2007 08:06:54
It wasn't "adapted." That was a kit available from the Elwood axle manufacturing company. They made front wheel assist axles for IH right up through the end in 1985.
Axles like this on older tractors like the M are fairly rare. The mechanism used to drive it is far from ideal (probably not all that reliable either), and I believe you're limited to 3rd gear with the front end engaged. On top of that, you needed 3 acres to turn the tractor around.
Wardner
06-18-2007 11:13:40
 Re: This is what I call a super m in reply to Nat 2, 06-18-2007 08:06:54
Nat
All gears function including low range on TA. Power comes from the top side of one of the cluster gears on the mainshaft. Probably 4th-5th.
I have an Elwood and it runs fine. I have not heard of reliability issues with the unit. It does look fragile, however.
All my tires are loaded and the rear has 10 weights. The front has a pair of weights. I also have four suitcase weights hanging off the front.
Yeah turning radius is not great. Probably similar to a crew-cab pickup.
Bob Kerr
06-17-2007 22:17:04
That is one bad momma M. I could use that to skid logs with! my M gets a little light in the front going up hill
