Pneumatic Lift-all on a Farmall A
farmallbob
06-18-2007 06:23:24
Good morning,
In the farmall a&b parts book (page 148 and 149)it shows a "lift-all operator`s control rod and automatic pressure release.In my seaching for lift-all parts I have gotten both operator contol systems(with and without pressure release)I would like to know witch is correct for the 1947year Farmall "A" gasoline tractor(or non distillate/kerosene) thank for any help Bob
gene bender
06-18-2007 10:40:20
 Re: Pneumatic Lift-all on a Farmall A in reply to farmallbob, 06-18-2007 06:23:24
I have and have sold several with the lift system when new but i will say the automatic system was used on the early models. With a mounted plow the automatic system would have been better as the pressure was off the the cycl when the plow was up and to trip the plow only required pulling the trip lever. This system would have been great for the B and BN187. Someday i am going to make that system work on mine.
farmallbob
06-18-2007 14:23:02
 Re: Pneumatic Lift-all on a Farmall A in reply to gene bender, 06-18-2007 10:40:20
thanks for the reply gene.I thought you would also like to know that I was able to buy a #5064E valve new from the judda wi. case I.H.dealer but still am looking for a 5063 E valve link,but I may have to make that part myself.also seeing as I have not got this system installed on my tractor yet I guess that the piston rod pushes rather than pulls in the cylinder is this a correct guess or not
thnks again Bob
gene bender
06-19-2007 02:39:00
 Re: Pneumatic Lift-all on a Farmall A in reply to farmallbob, 06-18-2007 14:23:02
yes the piston rod does push and either gravity or springs retracted it and sometimes both were used ex the cult.
