int'l 300 hydraulic pump
r. Bond
06-18-2007 09:24:44
I ran low on hydraulic fluid and since then, my tractor hydraulics have been slow, groaning and jerky. Have I screwed the pump or if it is a bleeding required, whats the best way to do it?
Thanks Ron
FromJB2
06-18-2007 19:40:41
 Re: int'l 300 hydraulic pump in reply to r. Bond, 06-18-2007 09:24:44
Hi Ron, could be a clogged inlet hydraulic filter. If it is 300U, then the filter is located in the reservior under the seat. Search the archives and you will find procedures to replace.
Jimb
Bill46
06-18-2007 10:00:59
Did you run it dry? If so the pump is more than likely gone. If it would still measure on the stick...it may just have air in it.
Drain a small amount out of the resovior in a clean coffee can and see what you get. if there is junk in it...you may have cooked the pump. Insure its full and cycle it a few times...maybe just air.
Also, there is a screen in the hyd tank...but that is a booger to clean.
