Order Farmall Cub Parts Online
CUB CADET
KEVIN FORSMAN
06-18-2007 12:28:55
I HAVE A CUB CADET TRACTOR WITH A KOHLER K341AQS ENGINE.THE TRACTOR IS TURNING OVER HARD,SO WE CHECKED THE COMPRESSION RELEASE SPRING ON THE CAMSHAFT.IT WAS NOT BROKE,BUT WE REPLACED ANYWAY.IS THERE SOMETHING ELSE IT COULD BE? WE DISCONNECTED DRIVESHAFT TO ELIMINATE DRIVE PUMP ALSO.
lstra
06-20-2007 07:52:32
 Re: CUB CADET in reply to KEVIN FORSMAN, 06-18-2007 12:28:55
My Cub Cadet 86 started turning over hard & kick back the engine if trying to start with throttle accelerated after it was run hot due to timing being off from improper point adjustment. Think compression relief springs weaken from extreme heat & don't do their job. Engine would get so hot it would hardly run. Readjusted the points & run ok but hard enjine turnover with starter persists.
Brownie450
06-18-2007 13:23:14
Make sure that the mower drive clutch is releasing.
