Ballast resistor question
Rags
06-19-2007 08:17:06
For a friend,Which wire does a ballast resistor connect to?Is it the coil wire? Thanks in advance.
DelMN
06-19-2007 17:50:05
 Re: Ballast resistor question in reply to Rags, 06-19-2007 08:17:06
If you have a 12 volt coil, the resistor should be between the coil and distributor. If you have a 6 volt coil, then between the ignition switch and coil.
El Toro
06-19-2007 14:51:56
You install the ballast resistor between the ignition switch and the coil. Hal
John T
06-19-2007 08:31:19
The Ballast Resistor is simply a two terminal In/Out voltage dropping (12 to 6) device. The wire down from the Ignition Switches IGN output terminal (hot when ON) connects to one terminal and the other ballast terminal conencts to the coils lil high input (NOT to distributor) terminal.
On a Pos ground system, the ignition/ballast connects to the coils lil - terminal and its other + terminal wires to the distributor. On a Neg ground system its the opposite, ignition/ballast wires to coils + terminal and its - wires to distributor.
So to answer your question, the ballast resistors output (NOT its input wire to ignition switch) connects to the coils lil terminal, being the lil + or - as described above depending on Pos or Neg ground.
NOTE dont confuse the coils lil + and - primary terminals (ballast and distributor) with its big center tower high voltage output where the coil wire atatches
John T
