clutch adjustment on farmall m
jeremy fugler
06-19-2007 15:31:11
i was wondering on how to adjust the clutch on a farmall m, wasent sure if you could adjust the linkage or if you had to adjust the presure plate. thank you
jeremy fugler
06-20-2007 14:13:00
 Re: clutch adjustment on farmall m in reply to jeremy fugler, 06-19-2007 15:31:11
thank you for the info
Hayfarmer
06-19-2007 18:55:44
you should be able to adjust linkage. You should have some movement of pedal (think it is like 7/8 inch) at top of pedal.
CNKS
06-19-2007 18:53:20
Linkage.
