W9 distributor
tinman700
06-19-2007 19:13:53
Im wondering if I can swap a dist. with a live hydro pump from an H and put it on a W9? I have seen counter clockwise mags out there for the W9, but I am wondering if it matters for a distributor? any help would be great.. thanks
Red48M
06-20-2007 17:52:59
 Re: W9 distributor in reply to tinman700, 06-19-2007 19:13:53
By chance does anyone have the part number for the correct W-9 gas distributer?
Roger in Iowa
06-19-2007 19:33:08
No you cannot use the distributor from anything other than a W9, 650 or 660 as the advance does not. It retards. I know. We used the wrong one and ruined a head and piston. You have to have the correct rotation!
Roger in Iowa
glennster
06-19-2007 19:24:15
the live pump from the h wont fit the w-9. you need one from a late m thru a 450 gas for the 9 engine. pretty sure the counter clockwise mags are for the wd-9.
Wardner
06-19-2007 20:30:11
 Re: W9 distributor in reply to glennster, 06-19-2007 19:24:15
The gas engine and the diesel engine in the 9 series both have the same rotation. Why? Because they both have an idler gear.
Distributers cannot interchange due to different advance curves. Pumps can interchange. Both engines use the same pump which is also the same as a 6 series diesel.
markloff
06-20-2007 14:42:37
 Re: W9 distributor in reply to Wardner, 06-19-2007 20:30:11
He's right you know.
Mark
