Re: IH 254 Hydraulic Stopped Working
Allan In NE
06-19-2007 19:18:04
Yeah,
I have the same exact tractor and no auxrillary remotes on mine either.
That drain is down on the left rear midsection of the tractor. I notice that someone has replaced that hydraulic pump on mine so maybe they were a weak link? Dunno.
I guess the next thing I would check is to see if in fact oil is getting to the pump and then if it is under pressure coming off the pump.
Allan
third party image
Whoops!!
06-19-2007 19:19:28
 Re: IH 254 Hydraulic Stopped Working in reply to Allan In NE, 06-19-2007 19:18:04
Just re-read this thing.
Mine is a 284. They are about the same, aren't they?
Allan
Shredder
06-19-2007 20:22:00
 Re: IH 254 Hydraulic Stopped Working in reply to Whoops!!, 06-19-2007 19:19:28
I'm not sure but I don't think a 284=254. The 254 is about 23hp and is a rebadged Mitsubishi MT210 I believe. From your uploaded image I would say they are different.
But your advice is good. I just need some basic hydraulic troubleshooting help. I'll check those things tomorrow. It's dark right now.
Norm
Shredder
06-25-2007 17:50:46
 Re: IH 254 Hydraulic Stopped Working in reply to Shredder, 06-19-2007 20:22:00
Well, I finally got back out there. Been busy and it's been raining for a week.
There is definitely hydraulic fluid moving through the system when the engine is running. I can see it in the filter housing when I remove the cap. Also the fluid level is full.
When I move the 3ph lever the pump doesn't run. Normally when I move the lever to raise the 3ph the engine strains a little. Now nothing happens. The pump isn't pumping.
What should I check next? Could the problem be in the relief or control valve? This tractor does not have power steering and the PTO is mechanical. I can see no visible problem with the linkage but I'm not sure I would recognize a problem.
There is water in the hydraulic oil but it was there before I shredded 2 weeks ago and I had no problems. I had drained and replaced some of the water-oil and will completely change it when I fix this problem.
Any help greatly appreciated. The pasture weeds are getting tall:(
Norm
Shredder
06-26-2007 16:35:19
 Re: IH 254 Hydraulic Stopped Working in reply to Shredder, 06-25-2007 17:50:46
Correction: the pump appears to be pumping. It isn't straining the engine like it normally does when I move the 3ph lever, but when I loosen the high pressure line fluid squirts out. I don't have the experience to tell if there is the correct amount of pressure though.
So, there is fluid moving through both the high and low pressure lines, but I can't raise the shredder. Other than that everything seems to be working OK.
Can someone help me with this?
Norm
