M carb needs alot of choke
jonnny2006
06-20-2007 09:50:18
i just bought a 51 M. it runs perfect with the choke half out. push it in, dies. now someone has welded on the part where the govner meets the carb..... could it be leaking from there or dosent the carb have any pressure there? just put in a nw kit on yhe bottom half ss like i said the govner tune was welded instead od a nut or what not. i know its getting to much air... when i first got it the float was stuck wide open snd it dint like choke. where are the important areas took look for, any help much appreacated.
RustyFarmall
06-20-2007 10:42:54
 Re: M carb needs alot of choke in reply to jonnny2006, 06-20-2007 09:50:18
If the carb has been broken and welded back together I'd scrap it and find another. Around $200 or less will buy one that is completely rebuilt and ready to bolt on. Not much point really in fighting the old one.
El Toro
06-20-2007 10:18:45
You may need to open the main jet adjusting screw near the bottom of the carburetor. This will enrich the fuel mixture. Hal
dej(jed)
06-20-2007 10:15:54
IF IT IS RUNNING ON HALF CHOKE THEN IT IS STARVED FOR FUEL. THAT COULD BE A GASOLINE LINE RESTRICTION, A CARB RESTRICTION OR EVEN VALVES THAT AREN'T SET RIGHT.
Bob Kerr
06-20-2007 10:02:58
Try this, wrap a peice of tape around that tube and see what happens. if it runs good there it is! Also check the float agin and make sure it is not hanging up on the side of casting or on a gasket. If that doesn't do it, adjust choke just enough to keep it running but running rough, spray carb cleaner around the carb and intake gaskets and anywhere else you susspect it might leak and if it smooths out that is where the air leak is. Good luck with it.
